Installing Adjustable fpr(firewall mounted)
Old Mar 15, 2006 | 04:19 AM
95gainfla's Avatar
smokes weed...everyday.
Default Installing Adjustable fpr(firewall mounted)
of course, the fpr i ordered is a firewall mounted one, so im kinda confused on how to install this.
I have an aem fuel rail, with both holes on the rail plugged(the random hole, and the fpr hole). I don't see anyplace that the hose from the fpr can go to?
i think i remember seeing a picture somewhere, and the aem rail had TWO males(one on each side), and the hose went to the one on the opposite side of the fuel line?
thanks
I <3 RooR!!!!!!
Old Mar 15, 2006 | 03:30 PM
SmokinS13SR20's Avatar
That ginger...
Are the holes tapped for a fitting?
Old Mar 15, 2006 | 04:50 PM
Jap's Avatar
Jap
VTEC Out
Get a 1/8NPT or whatever size the fuel rail threading is to Barbed hose thingy from Discount/Home Depot and run a line from there to your FPR ...
If your rail has a closed cap on one end take it off and find the barb fitting for that and run it off there ...
Hondata saves lives
Old Mar 15, 2006 | 04:58 PM
95gainfla's Avatar
ok, so the fpr has 2 big fittings, and one smaller one(for vacuum i guess)
what do the 2 bigger ones go to?
I <3 RooR!!!!!!
Old Mar 15, 2006 | 05:00 PM
Jap's Avatar
Jap
VTEC Out
One should say Outlet , one should say Return ... It may have two "outlets" for a dual fed fuel system
Hondata saves lives
Old Mar 15, 2006 | 05:16 PM
95gainfla's Avatar
doesnt say anything, ones on the bottom, and ones on the side.
I <3 RooR!!!!!!
Old Mar 15, 2006 | 06:20 PM
Jap's Avatar
Jap
VTEC Out
bottom is probally return
Hondata saves lives
Old Mar 15, 2006 | 06:37 PM
95gainfla's Avatar
ok, so i get the fitting from wherever, then the hose goes from fuel rail, to side of fpr, then out the bottom(return)...to where? thanks
I <3 RooR!!!!!!
Old Mar 15, 2006 | 11:42 PM
Jap's Avatar
Jap
VTEC Out
return line off FPR goes to where the stock Return line went . It should be a hose that goes to a small barb down on the firewall/front crossmember ..
Hondata saves lives
Old Mar 16, 2006 | 07:39 AM
95gainfla's Avatar
thanks dan, i remembered that after i went out side and actually looked at my car.
I <3 RooR!!!!!!
