Timing Belt ?
Old Mar 14, 2006 | 05:59 PM
lossgenius's Avatar
Default Timing Belt ?
How do I know when it is time to replace this? My car is at the 80k mark and I dont know if the previous owner changed it. If I need it changed how much am I looking at $$$ in labor....
Old Mar 14, 2006 | 06:04 PM
GOTTI's Avatar
OEM Parts Specialist
change it....you should change it at 60k, most owners before probably didn't do it.
If you have a dealer do it your probably looking at $500 or so...if you get one of us on here that know what we are doing ...well you might have to check with us
Old Mar 14, 2006 | 06:13 PM
TSX24L's Avatar
Just make sure you take it to someone who knows what there doing and doesn't claim to only because your paying them to do it.
If I were you I would go ahead and replace the belts to. Also and seals like the crank seal, cam seal or seals, tube seals, etc. . If you want. I would. Then you know that your shit is going to not leak(now) or in the future. If its never been done before on that car and with it being a 00 si I would go ahead and replace them if your going to do a timing belt i mean it is six years old.
Old Mar 14, 2006 | 07:53 PM
KJ's Avatar
KJ
bored at work
I'd replace the belt, water pump and tensioner pulley and spring if I were you. On cam and crank seals my preference is not to replace them if they are not leaking. Nothing worse than replacing a seal that wasn't leaking only to find out after you start the car up that you pinched the seal and have to do it over again. normal charge for a timing belt/ water pump should be $150 to $200.
