510cc injectors...civic low impedence?
Old Mar 14, 2006 | 01:00 PM
94lsteg's Avatar
BOOST IS BETTER!
Default 510cc injectors...civic low impedence?
I believe the injectors are from a EVO3(yellow top), they are peak and hold but they are low impedence. Now would I need a resistor box for these injectors for my z6 turbo? I have one hooked up right now , but i dont wanna destroy the wiring just to find out if it works, and then find out i have to wire it all again.....thx!
Old Mar 14, 2006 | 01:33 PM
lzylst's Avatar
Why don't you just use the DSM 450's I sold you ? You know they are peak & hold (low impedance) and require a resistor box.
No guessing game of what injectors you have. That z6 will blow up before you run out of injector with the 450.
Old Mar 14, 2006 | 02:04 PM
94lsteg's Avatar
BOOST IS BETTER!
the problem is , i had a 390 basemap at the time and thought i didn't need the 450's so i re-sold them lol.
Old Mar 14, 2006 | 02:13 PM
99B16Si's Avatar
pretty much all dsm injectors are low impedience. Use a multimeter and check the resistance to be sure. low impedience will be 2-3ohms, high impedience will be 12-14ohms.
or....
Just do a damn Google search you RETARD!!!! jk...kinda
Old Mar 14, 2006 | 02:24 PM
94lsteg's Avatar
BOOST IS BETTER!
or....
.....ask cronic (jeff) we searched these damn 510cc injectors for hours on Google Dave, they just arn't used that much. Hard to find info on. One guy said they were 12.9 on the ohm meter and then others said LOW impedence....
Old Mar 14, 2006 | 06:38 PM
lzylst's Avatar
multi - meter will be your best friend.......
Old Mar 15, 2006 | 05:57 PM
smoke3's Avatar
Its a secret
dsm injectors are compatible with each other. i didnt know that the 93 were 510cc the newer ones are 560cc. however they need a resistor box unless ur obd0
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
Old Mar 15, 2006 | 06:25 PM
GsEclipse02's Avatar
post in mitsu tech dumb ass
Old Mar 16, 2006 | 02:35 AM
94lsteg's Avatar
BOOST IS BETTER!
suck a dick julian
Old Mar 16, 2006 | 05:54 AM
Originally Posted by 94lsteg
suck a dick julian
