What am i missing... turbo setup
Originally Posted by smoke3
Yeah i am think about using chrome so ill hit u up as soon as i install all these parts..
??? I plan on getting the Apexi AVC - R Boost Controller. I was wondering after i get the car tuned for lets say 11psi and i used the boost controller to lower the boost that require a tune for each psi setting??
However, I recommend you have the vehicle tuned at your low & high boost settings.
gm 3bar supports up to 30.2 psi
motorolla 2.5 bar supports up to 22.9 psi.
oem honda map sensor supports up to 11.2 psi
I recommend you keep your boost levels under the maximum supported boost level of your map sensor so you can use a boost cut feature
Originally Posted by Keith
had to one up me... asshole...
If you get it tuned up to 11 psi you can go down in boost, but not up, with out re-tuning. I have a Greddy Profec II Spec B tuned to 10.5 on the high setting, I cruise around on the low setting most of the time and it is set for 7.5
ok i already have a dump tube. and y would i get a manula boost controller if i want to race?? so i jump out of the car pop the hood then turn it up. lol i think ill past on that bad boy.
Thanks for the help guys its been appreciated. All i need now is the arp head bolts clutch and AVC-R.
?? Can i use oem axles for daily driving
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
The Myspace Page
made.
- Its Game Time -
yea you can use oem axles for daily driving...i do in mine and im around 320whp...but it all depends if you wanna run this car at the track then get axles or run your car on the street from a stop then i would recomend getting them as well...
- Officially Retired....for now...
