another ecu question for you guys
Old Mar 11, 2006 | 11:15 AM
DOHC16CRX's Avatar
CARPET GUY
Default another ecu question for you guys
ok,i got a jdm obd1 p30 ecu.this ecu has no check engine code light on it.How do you tell what the code is if you are throwing one with these ecu's ?? WILL MY CHECK ENGINE LIGHT BLINK LIKE MOST NEWER ECU'S DO ?? P30's are a funny looking ecu's.almost half the size as a p72 etc.thanks for all the help..
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Mar 11, 2006 | 12:29 PM
hondachris1994's Avatar
hatchback1994
u have to use a jumper wire on the service connector,I have a p30 also pm me if u still have trouble
Old Mar 11, 2006 | 03:50 PM
kender's Avatar
gadget man
if you don''t have a service connector, in the instance of an obd1 conversion, you can hook a toggle switch to one of the wires ( not sure which but mtber should know) and the other side to ground, if you throw a code you flip the switch and the check engine light will blink to show the code.
U.S.S.A Crew Member #001
Old Mar 11, 2006 | 05:09 PM
DOHC16CRX's Avatar
CARPET GUY
ya,i was just reading about that..I will figure it out.I am just trying to get an idea before a start all this shit.My obd1 conversion harness came with pretty good wire diagrams but says nothing about if not having a check engine light.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Mar 11, 2006 | 06:32 PM
kender's Avatar
gadget man
looking at the ecu from the plug side, with the release tabs on the top, you'll have the center plug ( the smallest) and to the right the 22 pin plug (2 rows of 11 pins). on the 22 pin port the bottom row, 2nd pin in from the left side. this is the wire that is labeled check engine light on my jkobd harness that I used in my crx when I did the obd1 conversion. I was using a p28 but the p30 pinout should be the same with the knock sensor being the only added wires.
Old Mar 11, 2006 | 06:45 PM
DOHC16CRX's Avatar
CARPET GUY
straight..thanks man
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Mar 11, 2006 | 07:40 PM
kender's Avatar
gadget man
no prob.
Old Mar 12, 2006 | 03:22 AM
lzylst's Avatar
p30's can have two cases. The smaller case is JDM from what I've researched.
I have two p30's and was wondering so I checked into it.
Old Mar 12, 2006 | 04:09 AM
DOHC16CRX's Avatar
CARPET GUY
ya,jdm p30 look like micro machines..
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
