TPS question
Old Mar 8, 2006 | 03:59 PM
aka5000's Avatar
Default TPS question
1. Can you fix or rebuild one or is it better to just replace it?
2. Are they obd specific. Will a obd 1 or 2 tps match up with the plug on an obd 0 harness?
Old Mar 8, 2006 | 04:04 PM
poorboy44's Avatar
TR Balla Donor Supreme
Just to give you a quick heads up, the only way to replace it is to find one in a junk yard or buy a whole throttle body assembly from Honda. They're not sold seperatly
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
Old Mar 8, 2006 | 04:06 PM
95gainfla's Avatar
smokes weed...everyday.
replace it, or if you want, check all the wiring for breaks or to see if its damaged/has any breaks
not sure about the obdquestion, but im pretty sure they're different.
I <3 RooR!!!!!!
Old Mar 8, 2006 | 04:19 PM
60-1EK's Avatar
Engineer at the source
Never tried to fix one. You can interchange them with no issues.
JESUS SAVES
9.69@151 Street Car
JKOBD
