What injectors?
K, I'm buying another head friday and its going to make some big changes to my setup, I'm wondering what injectors I should run with this setup, if I plan to leave it n/a for awhile..
Block:
99 b18b1 block, bored .10 over
.10 over 10.8:1(with LS head, 11.3:1 w/b16 head, etc.) JE SRP Pistons
Eagle 4030 H-beam Rods
Micropolished Eagle 4030 Crank
Block decked .5 thousandths
Clevite77 Race Bearings
ARP Rod Bolts
ARP head studs
Bottom end completely balanced (good for 9k+ rpms)
Head:
93 b18a1
Ferrea Competition Plus valves
Crane Cams springs
titanium retainer kit
3 angle valve job
Crower 62405 full race cams with skunk 2 cam gears
Skunk2 intake manifold
Skunk2 68mm throttle body
DC 4-1 header (jdm itr knockoff, 2.5" collector)
Block:
ARP Rod Bolts
ARP head studs
Head:
93 b18a1
Crane Cams springs
3 angle valve job
370's are good for most na setups, 440's for some really powerful all motor monsters.
RC engineering has a nice little injector calculator for just this. Forgot the site but i think its www.rceng.com
HTH
HTH
Now residing in Atlanta.....
oh yeah , and you arent going to be able to daily drive it with the 405's , i mean the way you bitch about gas mileage and such.
fyi 50$ says you dont do it.
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
Stock injectors are fine up to about 190-195 whp.
+1
and this setup will only yeild about 170ish whp.
_Jake D
_Jake D
