UGHHHHH!!!!! screw hondas!!!! Help with LS!
Old Feb 28, 2006 | 07:14 PM
94lsteg's Avatar
BOOST IS BETTER!
Default UGHHHHH!!!!! screw hondas!!!! Help with LS!
OK so....
A friend of mine, Jared, bought a 96 ls motor for his 94 dc shell. We dropped it in yesterday and hooked everything else up tonight. Everything was hooked up and ready to go. Started it up, idled perfect, no smoke, everything looking good. Gave it some gas, sounded good. We let it idle for about 10 minutes after checking all the connections and then jumped in for a ride.......almost......Jared put it in first, let out the clutch a little and it just bogged and died with the extra gayness of smoke pouring from the header(he's running off the header right now). This motor is from a reliable shop, and was complete. I'm guessing it blew the HG--white smoke and some sort of liquid from the header, maybe antifreez/water? Would that be the HG? Anyway, we did start it up again and it idled but still smoked a little-Giving it gas made much more. I also drove it down the driveway....didn't make it far..just smoke a shit load and started breaking up like crazy.....HELP
Old Feb 28, 2006 | 07:16 PM
94lsteg's Avatar
BOOST IS BETTER!
....and yes, everything IS hooked up correctly and with correct fluids, wires, etc...
Old Feb 28, 2006 | 07:24 PM
95gainfla's Avatar
smokes weed...everyday.
sounds like the hg for sure..
I <3 RooR!!!!!!
Old Feb 28, 2006 | 08:46 PM
freakasis's Avatar
dont expect to get alota help with a title like that.
Old Feb 28, 2006 | 08:57 PM
94lsteg's Avatar
BOOST IS BETTER!
? why not? honda's dont make you angry sometimes?
Old Feb 28, 2006 | 09:07 PM
rangcrx's Avatar
engine building &amp;amp;amp;best
take the exu manifold off see if it is comeing from 2 or more chambers if it is only 1 then you might have a cracked csleeve or another problem
i love AUTOZONE
Old Mar 1, 2006 | 04:36 AM
Old Renegade's Avatar
Cool Runnings
white smopke is coolant being burned off so my 2 cents is that the head gasket said bye bye.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Mar 2, 2006 | 02:55 PM
SmokinS13SR20's Avatar
That ginger...
This and the head gasket are a possibility
Old Mar 2, 2006 | 03:09 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
look at the oil and see if it has coolant in it.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Mar 2, 2006 | 04:33 PM
94lsteg's Avatar
BOOST IS BETTER!
ok...soo....jared let the motor run for a while, put some carb cleaner in it.... it stopped smoking!!!!!!!! I donno what happend, but it was deff wierd. Tranny is like butter and runs NICE!
