Boosted crx question
Old Feb 28, 2006 | 04:43 AM
95GSTPROJECT's Avatar
Default Boosted crx question
I had a question for you guys out there....i picked up a crx lastnight....91 si it has a 94 civic ex 1.6 sohc vtec motor and its turbocharged......i bought it with the swap just sitting in there we hooked everything up....its alive!! but now i have some problems.....one....the turbo doesn't want to boost past 1lb the turbo is spinning freely w/o shaft play what could cause this?wastegate?he said the wastegate was adjustable?.....also what about the map sensor i thought this wasn't alowed to see boost....should i use a check valve within the vacum line? What about the distributer to use....should i use an obd0 si distributer? i don't know what distributer is in there now but it doesn't fit right with all the bolt holes.......Anything you can help with is awsome....i need it haha (by the way i we only payed 750 for the car)
Old Feb 28, 2006 | 10:17 AM
shimano's Avatar
Sounds like you have a boost leak ?
Old Feb 28, 2006 | 11:54 AM
Dori240's Avatar
I major one.. Check all the charge piping and the bolts from the manifold that hold the turbo on
JankyProductz: damn your car is scaring me and its not even together yet
Janky Productions
SPECIALIZING IN HONDA PERFORMANCE & REPAIR
2255 Starkey Road
Largo, FL 33771
www.JankyProductions.com
Shop: (727) 535-4058
Cell: (727) 420-3704
(727) 572-4340
Central Florida Performance
3201 118th ave N unit 10
st petersburg fl 33716
one bad ass fabricator!
Old Mar 1, 2006 | 04:30 AM
thanks i'll look at it today.....
