Oh Shit...Crankshaft Pulley!
Ok...now my crankshaft pulley is messed up...I heard a noise comming from my pulley and sure enough it was wobbling around so I shut my car off and tightened it. Started her back up still had the noise. I pulled the pulley off my car and the thread on the inside of the pulley were worn off pretty bad. My question is "Is my Crankshaft ok?" I know my pulley needs replacing. My car is a 99 Ls so what yr. pulleys can I use that will match up. Any help you can provide will be greatly appreciated. Thanks!
The threads themselves are in the crank, so if those are fucked, sadly, your crank is prolly fucked too....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
I had the same issue. I put it back on and it rattled off again at a later date. The second time it stripped the keyway off of the crank... Here's the lesson I learned. Replace the crank pulley bolt, and replace the pulley itself.
If you don't, you're asking for it. The bolt was ~$9 at the dealer.
Tight Fellas....just picked up the pulley and bolt thanks to a fellow TR member so all I need is the Key-way from Acura (think its $1.99). So you think the crank itself is ok?
you might be able to use the ls ones....what year b16? if its a 92+ than just use yer ls belts and if they are too long than get some 2000 civic si belts. or just go to the parts store and get a few differant sizes and just return the ones that dont work.
