B16 Turbo vs. B18C (gsr)turbo
ok... so your saying an itr will make more power enough to pay 2-3k more for the engine? if so then someone let me know ill buy a itr complete engine... im not poor and i dont wanna cut corners.
well, im not sayin that ur poor or nething but its like ls vtec but both head and block are vtec and work well w/ each other. the b16a motor is the closest thing to a typeR w/o the displacement. but yes an itr swap is potent
Japan's Finest
Japan's Finest
As for tranny go, for boost longer is better, the less time you spend on shifting the more time you spend in BOOST!!, I run a LS tranny, with LSD, and I run threw the traps in mid-top 4th gear, 3rd gear will do 65-100(a little long
4th gear will do 100-138 and 5th??? I donno I have never shifted into 5th and boosted. But the gears are GREAT for boost. other than the 3rd gear being a tad long its a great tranny for boost and highway racing(not that I do that
So If I were to mod a tranny for boost. I would use a LS (S80/Y80 hydro) trannys 1st, 2nd, 4th, and 5th And use a GSR 3rd. I dont think I would change the LS final drive outbut if I did I would go a hair shorter, mabye one that would drop about 4MPH from the entire range.. That would be MY!! tranny built of choice.. IMHO...
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
EFI-101 Certified
(941)628-4988
The GSR head and B16a flow so close under boost ,I would get which ever one can. If you have no plans of building it bottom end go with a GSR, flat top pistons and a little more cc is worth it. The GSR will make 300+ whp no problems bone stock.
www.lhtperformance.net.
727 344 1800
*Turbocharging* Engine building* Tuning *Intercooler piping*exhausts* headers* clutches ,fabrication and much more
13 years in the same location.
** HONDATA Authorized Dealer+ Tuner **
01 Type R-647whp street car w' AC - Cover of turbo magazine Feb 2008
01 K20a INSIGHT - Cover of Honda Tuning magazine June 2008
2011 KR-Z K20 powered CR-Z -Cover of Honda Tuning magazine April 2011
727 344 1800
