Big Brake question
Old Feb 6, 2006 | 08:38 PM
Hater's Avatar
Free base cocaine
Lightbulb Big Brake question
I have a set of brembo slotted rotors for my civic. But the stock calipers are for a 9 inch rotor, and the brembos are about 10 inchs. Im pretty sure they came off a teg. But im wondering if some EX calipers are in order or should I get some ls calipers, would they even fit?
Old Feb 7, 2006 | 05:58 AM
The Spectacle's Avatar
Spent more money than you
If the caliper is for a 9 inch rotor and you have a 10 inch rotor then no its not going to work.
Yes its time to upgrade. To what? Not sure...
Racing Integration
LHT Performance
My tuner is named Alpha
Old Feb 7, 2006 | 10:03 AM
Hater's Avatar
Free base cocaine
do you know what the size the rotors are on a civc ex or a teg?
Old Feb 7, 2006 | 04:14 PM
I'd go to the junkyard, and find calipers from 10 inch rotors.
Next, measure the distance between bolts that hold them to the hub carrier.
Next, measure the spacing from the 10 inch junkyard discs back to where the caliper mounts.
If distance between bolts is the same; and distance from caliper to disc is the same, see if the brake line/hose threads are the same. If all measurements match, probably you will have found an easy bolt-on,
..........*IF* the piston diameter and volume of fluid behind the piston is the same as you have with your current 9" discs. Otherwise, either pedal effort may increase, or there won't be enough brake fluid volume to activate the calipers.
.........It might be less effort to work overtime to earn the money and actually buy the brembo calipers for your particular car.................Keep us posted on what you find that works.-Bob
