endyn breather
Old Feb 5, 2006 | 11:21 PM
uncle bens wildrice's Avatar
i heard vtech
Default endyn breather
i need the endyn breather kit instructions. i bought the kit and dont have the instructions. so i need help bad thanks
Old Feb 6, 2006 | 12:36 AM
SPOONCIVIC's Avatar
FUCKIN LOOONG BEDD!!!
try the web site?
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
Old Feb 6, 2006 | 02:36 AM
therainforest's Avatar
this is the (off road) kit then
pull the stock breather box add the freeze plug to the port
remove both the 14 hex bolts on the block and install the 2 block vent tubes where the hex bolts went.
install the tubes to the tubes then to the bungs on the can
then use the extra hose and the tee to use the drain back feature
install hose on the drain then tee it to the bottom hose from the bung making sure the tee is lower then the can.
how this helped.
Old Feb 6, 2006 | 12:27 PM
1fasthatch's Avatar
Traction Problems
If you call endyne they can fax you the actual instructions its just one page If you can't get it from them I'll try to find mine and give you a copy
www.artofspeedproductions.com
Old Feb 6, 2006 | 03:09 PM
i heard vtech
true that well i thank you all, i tried the website and didnt get anywhere with it
Old Feb 7, 2006 | 02:56 PM
i heard vtech
tru tru well i will be doing it this weekend hopefully
