trans fill nut on a b series
Originally Posted by kender
how do you keep from over filling it? do you still remove the other bolt? If you do then ok, but if not I wouldn't reccommend this method. sometimes more is better but not on this.
you drain all the fluid out of the tranny , then you put 2.5 quarts in it ...its not hard.
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
When topping it up, remove the bottom bolt, pour oil into the speed sensor,
and when it comes out the bottom bolt, IT'S FULL!
........and that way you cannot overfill it.-Bob
