b series wobble problem under xcel pls help
Old Feb 4, 2006 | 07:44 AM
madlowcivic's Avatar
B20 V-TEC Baby.....
Default b series wobble problem under xcel pls help
Hey guys i have a wollbe that i can feel when i am under excelleration between 25 and like 45 mph took it to a shop told me it was my axels changed them still there, the shop shimed my motor thinking that was it, nothing . any way my half shaft and axels are good . could it possibly be my tranny or clutch???i did knotice slight oil around where my half shaft plugs into my tranny not sure if it was from there or my oilpan gasket ???? any way if any one has the slighest idea i have tried every thing pulled tranny off nothing seen out of the ordanry with my act clutch or tranny or throw out berring.?????OK and it is a b20 v-tech if taht helps it did the same ting on my old ls too ????mounts are not the issue here also checked that all when the motor was out???!!! Please help me!!!?????!!!
Old Feb 4, 2006 | 08:00 AM
TIM TIM TIM's Avatar
could be worse
well theres your problem... there is a phone in your motor!
aim:because tim said
Old Feb 4, 2006 | 08:08 AM
95gainfla's Avatar
smokes weed...everyday.
how exactly did you check the mounts?
I <3 RooR!!!!!!
Old Feb 4, 2006 | 08:56 AM
B20 V-TEC Baby.....
had them out visually loooking for cracks...the motor was out for a bit plus i have the poly insert on the rear fierwall mount.
Old Feb 4, 2006 | 09:45 AM
Old Renegade's Avatar
Cool Runnings
could be bad tires or a lost balance.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Feb 4, 2006 | 11:17 AM
jmelvin269's Avatar
Faster is Better..
bent rims or rim, tires also.
check your wheel bearings
Old Feb 4, 2006 | 12:53 PM
B20 V-TEC Baby.....
nope does it with both sets of tires i have,The old ones and new ones. checked the wheel berings when it was up in the air no wobble or play in the wheel berings.
Old Feb 4, 2006 | 12:56 PM
B20 V-TEC Baby.....
This is such a bitch i have tried all of these things b4. so i am led to think its a tranny problem or maybe a clutch problem ?? all the things that you would normaly think it was i have checked if not replaced think it would take care of this problem.
Old Feb 4, 2006 | 03:22 PM
B20 V-TEC Baby.....
Any ideas???
Old Feb 7, 2006 | 04:34 PM
If "wobble" means a side to side feeling, tires don't always stay in balance. Recheck them. If bearings are good, are the tierod ends good, too?
Are the tire sizes and rim widths the same, side to side? That, also will create an unstable condition.
Is the alignment the same, side to side? Excess Toe out will cause an unstable condition, too.
Have you also retightened *all* nuts/bolts on the front suspension?-Bob
