Brake Problem 92 civic rear brakes
Old Feb 3, 2006 | 12:12 PM
paconyx's Avatar
Default Brake Problem 92 civic rear disc brakes
Hey I need some help guys. I just put rear discs on my 92 civic hb, I swaped from 95 si. But the problem I'm having is that the rear wheels is appling pressure with out breaking.
So I change the proportioning valve from the 30/30 to a 40/40, and now the problem is still there. Do I have to change my master cylinder as well for this setup to work?
Old Feb 3, 2006 | 03:00 PM
Old Renegade's Avatar
Cool Runnings
maybe they are seized up.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Feb 3, 2006 | 05:52 PM
kender's Avatar
gadget man
the master cylinder does not need to be changed, that's like changing your radiator because you swapped in a different motor. since the civics from that time frame use a ton of the same parts the only thing you would have needed was the ppv which you say you already have. I would check to make sure that the pistons on the calipers were retracting all the way.
U.S.S.A Crew Member #001
Old Feb 4, 2006 | 10:16 AM
paconyx's Avatar
Good looking out, I'll take a good look at the calipers and let you guys know
Old Feb 5, 2006 | 10:00 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
what ebrake cables did you use?
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Feb 5, 2006 | 11:50 AM
itr1143-01's Avatar
i would say it sounds like the e-brake cables are to tight
Old Feb 6, 2006 | 11:05 AM
Right on.-Bob
