Teg issue- spark or fuel?
Old Jan 31, 2006 | 06:49 AM
blkackteg's Avatar
Now with more c5!
Default Teg issue- spark or fuel?
Sometimes when in lower gears and slowly accelerating, I get like a stall. The car doesnt stall out but I lose power. For example, ill be in second slowly accelerating and then around 5k it will buck then I quickly shift and it is ok again. Im guessing its either spark or fuel related? Where should I look to first?
Old Jan 31, 2006 | 07:06 AM
SmokinS13SR20's Avatar
That ginger...
Sounds like spark i could come by and check it out for you if you arent far away i have a spark tester
Old Feb 1, 2006 | 04:35 AM
blkackteg's Avatar
Now with more c5!
Thanks for the offer, but Im not in town right now. The wires and plugs are pretty new, so as far as spark- distributor? Does this sound like a distributor problem? Should I try a msd modified cap with external blaster coil?
Old Feb 1, 2006 | 08:46 AM
blackGS's Avatar
i just had the same thing it was the rotor on the dist. i repaced cap and rotor. all good now
Old Feb 1, 2006 | 08:52 AM
TIM TIM TIM's Avatar
could be worse
no need for aftermarket stuff. supposedly the stock is good for about 500 hp.. and i doubt your around there... so try the dist. or it possibly could be fuel, have your changed your fuel filter? or ran any injector cleaner in there??
aim:because tim said
Old Feb 1, 2006 | 10:15 AM
rangcrx's Avatar
engine building &best
i would i love msd and use nothing else i hate oem sparks
i love AUTOZONE
