vtec
Old Jan 31, 2006 | 04:49 AM
96acuraintegra's Avatar
Default vtec
i have a 94 gsr i need to know if it will hurt anything if i hook my vtec to a toggle switch or to the throttle and when i should turn it on if i should turn it on from an idle or wait til i'm up around 2-3 k rpm range
Old Jan 31, 2006 | 07:10 AM
SmokinS13SR20's Avatar
That ginger...
why do you wanna hook it up though a toggle switch or to the throttle...?
Old Jan 31, 2006 | 07:13 AM
The Spectacle's Avatar
Spent more money than you
yes it will hurt. do not do this. if this was a good idea don't you think more people would be doing it?
Racing Integration
LHT Performance
My tuner is named Alpha
Old Jan 31, 2006 | 07:14 AM
and when I say hurt I mean performance wise...your car will be slower...
Racing Integration
LHT Performance
Old Jan 31, 2006 | 08:49 AM
freakasis's Avatar
honda made vtec hit and just the right point for a stock or mostly stock car....leave it alone!
Old Jan 31, 2006 | 10:43 AM
TunerElite's Avatar
The Right-Wing
and if anything get a vtec controller,
Old Jan 31, 2006 | 01:13 PM
kender's Avatar
gadget man
not only will it hurt performance but you will be running the fuel maps for low rpm while the valves are opening for high rpms, timing will be off, and basically with long term use the engine life is decreased. also the vtec piggyback controllers do the same thing, so unless you get a controller that will also adjust your fuel map the controller will do the same as the toggle. get your ecu socketed and a rom editor or get it chipped, anything else is just bad engineering.
U.S.S.A Crew Member #001
Old Jan 31, 2006 | 02:33 PM
That ginger...
+1 on getting an socketed and chipped ecu then i don't hink it would hurt if the computer was set for it to be like that. IE Right fuel, timing, spark maps....
Would be just like having a higher lift/more duration cam/s at low rpms thereby almost totally eliminating vtec
Old Feb 1, 2006 | 02:36 PM
ok where can i get my ecu socketed and chiped at and i was asking because a friend of mine said that he did it and it works fine thanks alot for the info i'm new to honda's and acura's
Old Feb 1, 2006 | 03:20 PM
www.phearable.net
Racing Integration
LHT Performance
