Gsr in my Ls, easy?
Has to many projects
on
Gsr in my Ls, easy?
My 98 Ls is getting old and I have compression of 190 in 1,2,4 and 80 on 3. So I was thinking maybe just getting a Gsr motor and putting that in. I know the Gsr has a knock censor and V-tec to wire up, but I am assuming that everything ells would just be plug and play. Am I correct in saying this?
Cburke.industries.
Custom suspension bars, metal fabrication.
Cburke.industries.
Id do a leakdown test to see where your losing compression before you condemn the engine. Unless you just need an excuse for 40 more hp
Now residing in Atlanta.....
on
LOL, it’s the rings. I put oil down the spark plug hole and the compression jumped up to 190 like the others. I am guessing that I’ll just need to get a Gsr ecu and run the V-tec wire from the ecu to the V-tec cyl, then run one for the knock. Do you guys think I will have to do any wire swapping or should the spots be open already?
It's going to be about a month or so, but I figured I'll trade my 97 Honda CBR600 for one or something like that.
Cburke.industries.
Cburke.industries.
Deff go with a gsr...Dont worry about the knock sensor take the gsr ecu to john vaga and have him make u a gsr map with no knock sensor i did the same thing....As fas as mounts and linkage your set
Springhill
22" Nothing less
Springhill
22" Nothing less
Yeah just wire vtec...If you want it done right and clean take it to Neil Sutton and i heard he wires V-tec for 30 bucks and he uses all oem wires and the install is very clean
Springhill
22" Nothing less
Springhill
22" Nothing less
on
do I need to change the t-body cable? I have a Skunk2 intake manufold on my Ls now, can I use that?
Cburke.industries.
Cburke.industries.
