ls/vtec rex is almost done.
ya i know i have been building this for fucking ever.its almost done..i just thought i would give an update on what you guys have to look forward to ..some will be seeing lots of tail lights..lol..i will give you the complete break down..
b18a block
82mm jdm itr pistons
glass beaded rods w/ arp bolts
all acl bearings(rods,thrust,mains)
ls crank
oem CTR single belt 1.9lb crank pully
brand new oem itr oil pump
gsr water pump
93 gsr pr3 head
dual port flow valve springs
oem p72 timming belt
jdm CTR cams
str cam seal
skunk2 cam gears
itr valve cover
skunk2 pro series intake manifold
BBK 62mm throttle body
rc 310 injectors
b&m fuel pressure reg and gauge
oil pressure gauge
255 fuel pump
golden eagle 6an ls/vtec oil line kit
JG full race headers into 2 1/4 w/ apexi n1
jdm S1 tranny w/ kaaz lsd
ACT h025 pressure plate
ACT street strip sprung disk
ACT 12.5 lb flywheel
hasport mounts and linkage
b&m ball bearing short shifter
chipped pwo ecu
jdm spoon sports ef vtec controler
ZEX dry kit w/ 75 shoot
now the car...
91 crx si gutted to hell.nothing inside.
new 15" nippon racing 12 lb wheels(gunmetal)
BFgoodrich g-force drag radials
koni adj. yellows. all around
nue speed race springs
front and rear camber kit
complete energy suspension hyperflux kit installed
JDM sir front spindles(11")
91 teg brake booster w/ master cylinder
bremmo front and rear cross drilled and slotted
ebc pads
this shit has been going on forever..i have it all running and drove it a few times..i keep changing shit around so its down alot cause i have no time..just changed the suspension set up to the yellows and put the sir spindles on..now i am changing it to obd1 to get some better tuning programs.car has about 5 hours and 4 oil changes.no oil leaks at all !!..big ups to brendon(rangcrx) for the short block build.he did a kick ass job..this motor runs so smoothe and quete.I should have it ready real soon..sure you guys will see it at the track..
b18a block
ls crank
gsr water pump
93 gsr pr3 head
jdm CTR cams
str cam seal
skunk2 cam gears
itr valve cover
rc 310 injectors
oil pressure gauge
255 fuel pump
chipped pwo ecu
now the car...
ebc pads
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
engine building &best
on
cant wait to see it i might stop by monday or tuesday your casa i gotta go to tompsons to pick more parts up,BUt glad to hear all is Great!!!
i love AUTOZONE
i love AUTOZONE
they do very well if you ask me..i can tell a huge differance.with street tires i can spin threw 4th..them g-forces are very soft tires..they should hook up with suspension work on any car i would think..if they are not enof then i will change that around as well...i am trying tons of differant shit..thats why its still not on the road..i have a few pics in my gallery..i willl get some new ones up..the pics are last months deal..this month its alot different...i will get it the way i want it one day...
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
everything sounds great but i would toss the ctr crank pulley they have been known to cause bearing and oil pump failure. you don't want to put all that time and money into your motor and have it die from a crank pulley, plus gains from the ctr pulley opposed to a oem one are minimum and not worth the risk of your motor failing.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
ya i know the problems with the ctr pullies but i took it to dominique at modern performance along with the new act flywheel and had it all balanced.the pully was right on..the flywheel needed some work.i made sure to get everything right on and balanced.with it all balanced i think it will be ok...
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
we'll have to get our race on- mine might give you a run for your money- youve seen it, but dont give anything away just yet...
Quote; Stan Marsh from "Southpark", concerning his friends Cartman, Kyle, and Kenny obsessing over facebook:
"You guys are retarded, I'm playing XBOX."
