What is this??
Okay, Thanks. How would I go about getting some kind of wire diagram for it. I've called Greddy in Cal. and in N.J and they said that they don't have any info on it....
Somebody please help me out.
Just another day in paradise...living the dream!!!
I have all the schematics for it. 500 bucks and I will photocopy them.
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
500.00 bucks?????????? You better install it and also finish my swap for me. Then I'll give you a pat on the back.
Greddy Fuel Control Unit
Blue wire to Injector #1
Orange wire to Injector #2
Yellow wire to Injector #3
Purple wire to Injector #4
Brown wire to RPM wire
Gray wire to ground
Black wire to ground
Red to 12V switch
Map sensor wiring...cut the sensor wire. Side going to the MAP sensor goes to the White wire. The side going to the ecu goes to the Green wire.
