someone get my car running...$$$
Old Jan 4, 2006 | 09:50 AM
Derka's Avatar
TR Balla Donor Supreme
Check the grounds. Did you take off the one by the thermostat housing? the car will not run without that.
1998 crv daily beater
Old Jan 4, 2006 | 10:54 AM
freakasis's Avatar
checked firing order....tried to advance/retard the dizzy (no change)....and i did not remove any ground wires...and i checked them all anyway...they are fine....this thing is pissing me off.
Old Jan 4, 2006 | 11:08 AM
Open the dizzy, look if the rotor is pointed at the #1 plug wire, as no 1 comes up on compression........(all no 1 valves will be closed).
Do you know how to do a static timing?-Bob
Old Jan 4, 2006 | 05:05 PM
freakasis's Avatar
what is static timing?
Old Jan 4, 2006 | 11:08 PM
Hailer's Avatar
I am Jeff
these sites might help ya out..
D-series Camshaft removal
http://www.geocities.com/hondadog19...aftRemoval.html
D15b1/b2/b7, D16a6 Rocker arm bolt sequence for removing the camshaft.:
http://www.redpepperracing.com/technical/115/abf
D15z1, D16z6 Rocker arm bolt sequence for removing the camshaft.:
http://www.redpepperracing.com/technical/115/abe
http://www.redpepperracing.com/technical/115/abz
z6 cylinder head removal
http://www.redpepperracing.com/technical/115/abb
D16y5,7,8 96-98 Cam removal
http://www.redpepperracing.com/technical/138/abj
http://www.geocities.com/hondadog19...camremoval.html
Valve adjustment/inspection for D16y7, D16y8
http://www.redpepperracing.com/technical/138/aal
http://www.redpepperracing.com/technical/138/aax
D16 Camshaft Comparison
http://www.hadamotorsport.com/tech/...6camshafts.html
Cam installation articles:
http://importtuner.com/tech/0102it_zex/
Barack Hussein Obama is now your president.. For all who voted for him.. Don't bitch when he doesn't come through for you. Why do you think our enemies wanted him to be president...? Because he is weak..
http://www.youtube.com/watch?v=8sj91NH5fvw
http://www.youtube.com/watch?v=hU9iCANi02o
Old Jan 5, 2006 | 04:24 AM
dippincrx's Avatar
save the s.o.h.c
check your plugs, and regap them.
Old Jan 5, 2006 | 03:59 PM
  #17 (permalink)
Jay's Avatar
Jay
Janky
Pm me if this car is still not running and let me know what area you are in.
Aim: o JankyJ o
http://jankycrew.com
Old Jan 9, 2006 | 06:54 AM
  #18 (permalink)
Static timing is when 1. you line up your timing marks. 2. you put a test light where the spark is triggered, and slowly rotate the distributor until the light comes on.
It will now be timed to where the spark arrives at the same time your timing marks line up.-Bob
Old Jan 9, 2006 | 07:44 AM
  #19 (permalink)
freakasis's Avatar
dont i want it to spark before they line up?
Old Jan 9, 2006 | 08:22 AM
  #20 (permalink)
Get it running first, then whip out your timing light. To set the advance.-Bob
