flywheel pins
Originally Posted by KJ
I would actually leave them in and possibly just add the third out of a spare flywheel. My only concern is that maybe the bolts that hold the pressure plate down might be more prone to backing out.
Well the bolts main purpose is to clamp the pressure plate. The dowels provide a tight fit to the pressure plate and prevent any rotational movement of the pressure plate relative to the flywheel. The bolts on the other hand are not a tight fit and even when clamped down might be prone to provide a small degree of movement under hard launches and shifts. This action might cause the bolts to back out over time. This is just my theory on why I wouldn't run it without dowels I have no proof this will happen, just how my brain thinks it might happen.
Gracie Barra Clearwater
i see what your saying KJ. When i pull the flywheel off the car ill try and pull a pin out and put it in this flywheel, hopefully it will come out without a fuss. Thanks again for the info
