probably a stupid question
Is the greddy e-manage pretty much the same as a apexi safc 2? Can you run both or is that completly stupid. Thanks
NOW Im SPRAYING
Dont Be A PUSSY Spray That SHIT!
www.ogrbreaks.com
http://<span style="color:Blue">www....eaks.fm</span>
HUNGRY? DON'T GO AND HUNT FOR DEER JUST FUCKING HIT THEM WITH YOUR RIDE!
NOW Im SPRAYING
www.ogrbreaks.com
anyone?
NOW Im SPRAYING
www.ogrbreaks.com
NOW Im SPRAYING
www.ogrbreaks.com
I dont know if the E-manage is a standalone or a piggyback to the stock computer.
Since I believe the E-manage can do all that the safc can and more, you only really NEED the Emanage.
It would be nice to have the safc hooked up for its display though. You could view your TPS,MAP,rpm, etc while the E-manage I think you have to have a laptop to view things.
If you have both hooked up, the safc will trick the signals going into the Emanage and cause it to run richer or leaner like it does to a factory ecu.
The Emanage will let you tune ignition tables also.
These are just assumptions on the Emanage, Im sure someone will correct me that has hands on experience...
Now residing in Atlanta.....
not to many good recommendations on either. if you are going to run one only use one or the other. but your best way would be to take your car to a good tuner and run one of the many good tuning programs there are.
Originally Posted by 95gainfla
just go crome/socketed/chipped obd1 ecu
Cant auto
NOW Im SPRAYING
www.ogrbreaks.com
NOW Im SPRAYING
www.ogrbreaks.com
