d16z6 or d16a1 turbo?
Old Dec 18, 2005 | 08:52 AM
94lsteg's Avatar
BOOST IS BETTER!
Default d16z6 or d16a1 turbo?
first off, i have the option to get a a1 with 35k miles.
Which one would be better for boost? And will my d-series turbo mani fit the a1? money is not a issue
Old Dec 18, 2005 | 08:56 AM
PooN_Lude's Avatar
if you already have a z6, keep it. the a6's are stout and take boost well but the z6 vtec heads flow better and if your boosting the stock motor the z6 is going to make more power
Old Dec 18, 2005 | 09:08 AM
94lsteg's Avatar
BOOST IS BETTER!
i dont have a z6 yet, i have the option of any swap i can find under400 bucks
Old Dec 18, 2005 | 09:11 AM
Derka's Avatar
TR Balla Donor Supreme
isnt an a1 the dohc ? i wouldnt bother with it, i would use a z6. They do pretty well with boost. I was just reading of one with a home made setup pushin 244 to the wheels.
1998 crv daily beater
Old Dec 18, 2005 | 09:14 AM
94lsteg's Avatar
BOOST IS BETTER!
on a stock block?
Old Dec 18, 2005 | 10:01 AM
PooN_Lude's Avatar
o0h shit, i thought it said d16a6..my bad son! get the z6 though, Tons of people have used it and its proved to be worthy
Old Dec 18, 2005 | 10:06 AM
PooN_Lude's Avatar
Yeah, the a1 and zc are both dual cam d series, im pretty sure the a1 has different tranny/engine mounts and might be a bitch to swap..+2 votes for z6
Old Dec 18, 2005 | 11:42 AM
Derka's Avatar
Originally Posted by 94EJ1coupe
on a stock block?
Yup pretty much stock everything minus the supporting mods. Its in this months sport compact car. I got bored at work and read it
Old Dec 18, 2005 | 11:46 AM
Derka's Avatar
or you could always take your stock y8 and put a non vtec head on it, to lower the compression.
Old Dec 18, 2005 | 12:22 PM
Jaso0on's Avatar
Is now ballin!
He doesn't have a stock y8, he has a shell right now..
Also doug, look at some of these numbers, and their setups and you will be VERY VERY impressed.. http://turbod16.com/viewtopic.php?t=4140
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
