vafc/ need help with instalation
Old Dec 13, 2005 | 04:55 PM
91 TURBO's Avatar
im a ricer!!
Default vafc/ need help with instalation
i have an 88 crx si, with a pm6 ecu. i need a diagram so i can hook up the vafc to the ecu, and syliniod. thank you so much. oh, its a complete z6 in the crx.
Old Dec 13, 2005 | 06:44 PM
91 TURBO's Avatar
im a ricer!!
please, anyone?
Old Dec 14, 2005 | 04:44 AM
91 TURBO's Avatar
im a ricer!!
Old Dec 14, 2005 | 06:11 AM
Duke_nukem's Avatar
hang on. I have it.
I will IM you in a minute
_____________
91 Hatch B16-T
13.0 @ 110 - 7psi
--Even my Truck has Vtec--
Old Dec 14, 2005 | 06:22 AM
Jay's Avatar
Jay
Janky
Here ya go every thing you need:
http://www.apexi-usa.com/pdfInstallation/23.pdf
Aim: o JankyJ o
http://jankycrew.com
Old Dec 14, 2005 | 05:18 PM
91 TURBO's Avatar
im a ricer!!
i already have that, but that is for obd-1 ecu's. im still obd-0.
Old Dec 15, 2005 | 06:24 AM
Duke_nukem's Avatar
Here you go... Its Kinda Crappy, But If you Email me I can send you the File that is in a spredsheet.
How to Instal A'pexi VAFC in a CRX
V-AFC VTEC controller ECU PIN location
Red & Orange wire splice/connect to A15 (yellow/black)
Green wire RPM signal splice/connect to B15 (white1)
Pink wire VTEC signal output to VTEC solenoid (green/yellow)
Purple wire VTEC signal input not used on PM6 ecu
Blue wire VTM signal not used on PM6 ecu
Gray wire Throttle signal splice/connect to C7 (red/blue wire)
Yellow wire Pressure signal output cut/connect C11 ECU side harness
Si/Hf = white1 , DX = orange
White wire Pressure signal input cut/connect C11 ENGINE side harness
Black wire Ground splice/connect to A16 (brown/black wire)Engine side harness
Brown wire Ground splice/connect to A16 (brown/black wire)has to be connected closer to the ECU
_____________
91 Hatch B16-T
13.0 @ 110 - 7psi
Old Dec 15, 2005 | 06:36 AM
Jay's Avatar
Jay
Janky
those instructions have obd0 in them the Ha-1 diagram is a obd0 pin out.
Aim: o JankyJ o
Old Dec 15, 2005 | 06:43 AM
Duke_nukem's Avatar
Tru dat.
_____________
91 Hatch B16-T
13.0 @ 110 - 7psi
Old Dec 15, 2005 | 12:30 PM
91 TURBO's Avatar
im a ricer!!
oh cool, thanks
