got a sputter
Old Dec 11, 2005 | 08:16 PM
aka5000's Avatar
Default got a sputter
Ive got a sputter at idle and cruising. It seems to be fine during acceleration. First thing I changed was the fuel filter. Now I think its a bad injector....
Whats your opinion?
How would I go about testing the injectors?
(obd0 b16 pr3)
Old Dec 11, 2005 | 11:03 PM
SleepingB18's Avatar
just mike.
Have you replaced your cap and rotor, plugs wires lately? Could have a fouled plug.
Old Dec 12, 2005 | 03:27 AM
therainforest's Avatar
first off listen to all the injectors with a stetescope or just place a screwdriver to your ear and to the injector and listen to hear if the injector is opening. is there a mil if so check what cylinder the dtc is for then subsitute the bad cylinders (misfire cylinders) injector for a good know injector. clear the code and see if the code changes to cylinder the (bad) injector was swapped to. i personally would try this with the pluges before the injectors. plugs are way more common to cause a misfire than injectors.
or if needed just do a tune up cap rotor plugs wires.
Old Dec 12, 2005 | 03:39 PM
aka5000's Avatar
no codes... Its got new plugs and wires. All four cylinders fire but it sounds like its misfiring (sputtering) during idle. I will double check the gap on each plug and consider a new rotor and cap. anything else?
Old Dec 12, 2005 | 05:17 PM
just mike.
Id take out the injectors, I believe those have litttle screens in them. clean them up, theres got to be some debris somewhere.
Old Dec 12, 2005 | 07:12 PM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
Inspect your plugs, theyll tell you alot about how the cylinder is firing...
Now residing in Atlanta.....
