ef steering rack bushings?
Old Dec 6, 2005 | 08:02 PM
dippincrx's Avatar
save the s.o.h.c
Default ef steering rack bushings?
ok heres, the deal, when i shake my steering wheel i hear a clunk, check my balljoints my driver side was bad so i changed it. well its still doing it inners are good (but i do have a extra set) so im thinking my rack bushings. most people tell me its not that often a rack itself goes bad. anyone else have this problem? also where i can find some poly rack bushings locally lmk thanks
Old Dec 6, 2005 | 09:04 PM
KJ's Avatar
KJ
bored at work
sounds like the inner rack joint which basically means a new rack is needed. You can try the bushings and if they don't do the trick they can always be transferred to the next rack.
Old Dec 6, 2005 | 09:13 PM
rangcrx's Avatar
engine building &best
+! see it always on ef NO POWERSTEERING so the racks suck a quickfix is tighten the 14mm nut on the rack JUST a lil the tighter you make it the harder it is to steer but will make the wheel lil stiffer
i love AUTOZONE
Old Dec 7, 2005 | 04:17 AM
dippincrx's Avatar
save the s.o.h.c
where on the rack will i find this bolt?
Old Dec 7, 2005 | 05:06 AM
rangcrx's Avatar
right at the gear jack the car up right under the drivers side
i love AUTOZONE
Old Dec 7, 2005 | 02:37 PM
dippincrx's Avatar
save the s.o.h.c
ok i looked the one right under the shaft is a 14mm but bitch aint budging at all
Old Dec 7, 2005 | 03:40 PM
R91Si's Avatar
the rack is prob. worn out...
Old Dec 7, 2005 | 03:41 PM
TSX24L's Avatar
could be several things. Does it make a rattle like sound when going over any bumps? Like the front end is loose?
*tie rod ends
*check loose suspension related bolts LCA bolts, worn bushings etc.
*balljoints
*struts
*wheel bearing
Old Dec 7, 2005 | 04:46 PM
dippincrx's Avatar
save the s.o.h.c
yea i know it needs front struts, it does rattle when i go over bumps, but when parked and i shake the wheel really fast and short i hear it clunking in teh rack got new inners and a new out driver, guess this is gonna force me to sell my turbo kit
