Timing belt change and p0172 code
Old Dec 5, 2005 | 04:35 PM
PixelBender's Avatar
out of focus
Default Timing belt change and p0172 code
I did a little bit of searching and came up with nothing. A freind of mine had his timing belt changed 2KSi B16A2. Now his car is throwing the P0172 code. I am curious as to what could cause this. His car ran fine before the work was done.
I think the timing is off somehow. HIs mechanic used Alldata and they had my Helms manuel for reference.
Any insight would be helpful.. cause I am going to be doing the timing on my 2KSi soon.
Old Dec 5, 2005 | 06:16 PM
95gainfla's Avatar
smokes weed...everyday.
P0172 means you're running rich.
I <3 RooR!!!!!!
Old Dec 6, 2005 | 04:33 AM
out of focus
Would changing the timing belt cause this? The car was running fine before the timing belt change.
Old Dec 6, 2005 | 06:52 AM
95gainfla's Avatar
most likely the guy who used the alldata messed the fuel map up or something.
I <3 RooR!!!!!!
Old Dec 6, 2005 | 04:23 PM
out of focus
Hey it's not like he plugged the alldata in http://www.alldatadiy.com/.
It was used as a reference
Old Dec 6, 2005 | 07:09 PM
95gainfla's Avatar
oh, do you have a wideband a/f gauge? if not, get one.
I <3 RooR!!!!!!
Old Dec 7, 2005 | 03:06 AM
therainforest's Avatar
hey i was the guy you talked to from palm harbor honda any luck on the code?
Old Dec 7, 2005 | 03:34 PM
00TEGLS's Avatar
Your timing is off I will bet your t- belt is off a tooth.
Old Dec 7, 2005 | 03:39 PM
out of focus
No thats not me, I'm asking for Paul (I work with him) I am thinking that one of the cams moved when the timing belt was put on. That would explain the rough Idle and the bogging feel from idle. He also said they did the cam seals but I don't think it would kock the dizzy that much out of time to cause these symtoms. I suggested that he should have the shop re-do the timing, maybe they missed something.
Old Dec 12, 2005 | 02:07 PM
ironwrench's Avatar
most the time when a car came in to acura with a code for rich or lean and just have a t belt done by a aftermarket shop...the timing is off........
