b18 block type r crank
on
Ok im looking to build a motor but can I use a type r crank in a b18 block(LS 99) and then put a b16 head on it would this raise the compression. Im looking to go turbo so Im not trying to raise the compression would my stroke be longer? Is this a good or bad set up for a turbo. May use stock rods and pistons or may upgrade,lmk what you guys think.
engine building &best
on
no the crank will not work with your stock rods,you will need typeR/gsr rods
i love AUTOZONE
i love AUTOZONE
A vtec head will make more power than a nonvtec one in both N/A and turbo setups. Bigger and lighter valves,bigger cams(vtec),better ports all help airflow and thats what makes power.
If you can get a vtec head, do it...
Stock LS/B16's have made well into the 300whp with good tuning. If you think you may need or want more, BUILD IT
Now residing in Atlanta.....
U would actual want to use the Ls crank instead of the Type R, for the 89mm stroke, and like Pyro said, since your building the block, mine as well save up $800, and buy pistons and rods. I would also recommend a block girdle if you dont have one, to make the block more sturdy, its like $140.00 new from Honda, and you need Vtec main bolts, which are like $20.00. With a Vtec head, and forged pistons and rods, 300whp will be easy to hit, and it will be safe. Good Luck!!
My Old Honda
My Old Honda
I have a block guard for sale for 45!!!! brand new
To answer you question, you stroke would be shorter with the type R crank. Couple that with the shorter rods of a b18 LS and you end up making very poor compression. Not sure if anyone has ever calculated it, though. Would be interesting to see. Motor like that might be able to take 50 lbs of boost.....LOL
