compression test
well i did a compression test on my car today and the numbers are:181,190,185,184
its a stock h22 motor and to me it seems kind of low
if anyone knows the right numbers please inform me.thanks
You are primarely looking for consistency. Did you do the tests at Wide Open Throttle ?
to do it corectly you are supposed stop fuel being sent into the cylinders I usually pull the injector plugs and your supposed to open the throttle body full throttle then crank the motor over with all the plugs taken out of the cylinders. thats what the ASE certification board says.
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
+1
NO EXCUSES for my lil FWD! Cmon RWD's n AWD's, lets DIG!
STEISS RACING all the way
HONDA ENGINES from oem to EXTREEM
www.myspace.com/streetracin_cwby
http://www.facebook.com/#!/profile.php?id=1433200141
Also know that different gages will read differently. I can pull two different gauges I have out and get a +20 psi difference when going between an old cheap set I have and a Matco set I have. The key is to look for consistency as was previously mentioned. You're results look ok and you don't have anything to worry about.
Gracie Barra Clearwater
there's only one kind to use! SNAP ON !!!!!!!
