Crankshaft Positioning Sensor???
Old Nov 25, 2005 | 04:01 PM
TRD_Tc's Avatar
Using The Force Of N/A
Default Crankshaft Positioning Sensor???
Ok I'm pretty sure I'm right on this part being my problem. My car just dropped its timing belt a week or so ago and I finally had a few hours to work on my repairs. I found that my Crankshaft postioning sensor had been torn from its original spot and it was hanging by one wire. I guess when my belt broke it hooked onto this sensor. I put the wires back together and let it go from there. Once I finished everything else I started up the car and it sounded like the timing was off but I checked it with a timing gun and it was dead on. My guess is that the sensor is Junk. Does this sensor (when bad) make your car run like its timing is off? Thanks.
Old Nov 25, 2005 | 04:22 PM
95gainfla's Avatar
smokes weed...everyday.
that sensor times injector pulses.
(someone correct me if im wrong?)
I <3 RooR!!!!!!
Old Nov 25, 2005 | 04:31 PM
calloway01's Avatar
Big block
the car will not run. it tells the dizzy when to fire.
Big block mustang killer...get some
-Mike
Old Nov 26, 2005 | 01:28 AM
TRD_Tc's Avatar
yeah but what I'm thinking is that there is a short somewhere. the car runs (barely) and like I said above the timing is dead on but it doesn't run like it is (at idle).
Old Nov 26, 2005 | 06:42 AM
freakasis's Avatar
you checked the spark timing not the valve timing. take the upper timing cover off and check the valve timing. if that is dead on than i would say the sensor is your problem.
Old Nov 26, 2005 | 01:33 PM
Derka's Avatar
TR Balla Donor Supreme
When the car dropped the belt did it bend any valves? Honda motors are interfence engines
1998 crv daily beater
Old Nov 26, 2005 | 02:54 PM
TRD_Tc's Avatar
well...put on the new sensor...turns out my my rings are shot so my block is scuffed up too (anyone want to buy a used ls block to bore out or eagle rods?). anyways I'm planning on doing another rebuilt to my motor and i'm just going back to complete stock.
Old Nov 26, 2005 | 04:57 PM
Jaso0on's Avatar
Is now ballin!
Damn man, you have had some BAAAD luck with this car... Look up, things can only get better! gl with it.
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
