cat removal help
TR Balla Donor Supreme
on
cat removal help
well i had a stupid issue that i finally traced to a clogged cat(long story).
the only problem is, i cant get the damn thing off to unblock it. i busted a 3/8" craftsman ratchet trying.
anyhow, a friend told me to use a cutting torch to heat up the nut and then to try it after it has cooled a little bit. the only problem is i dont have a cutting torch. do you think a regular blowtorch will heat it enough to remove it and if so, will the heatshield keep the bottom of the car safe while im working on the top nut?
thanks in advance!
thanks in advance!
oyea a regular torch will work but make sure u have somethign there in case of fire just to be safe you dont want to lose ur car from trying to remove a cat lol just heat it up and it will still be hard to turn yea but not to hard good luck with it man
ive used a angle die grinder to cut the bolts off in the past works good and a bit faster and safer then tourching it unless you have a cutting tourch.
-Jay
-Jay
-Jay
-Jay
I <3 RooR!!!!!!
I <3 RooR!!!!!!
Originally Posted by bluEG6
cut out the cat and weld a test pipe....... its raspy though.
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
Originally Posted by SPOONCIVIC
i got a test pipe to a thermal cat back on my crx b16 and it sounds good,at a stand still you cant even hear that the cars on.
+1 but my setup is on a hatch.
