aem boost control
aem boost control
i have the whole aem set up in my crx and and looking for a boost contoller. i've heard that you can use the aem to do it but can it be done through stages or is it just a hi/lo thing. just trying to take care of some little traction problems and also have a good boost controller.
I have used it more than a couple times. It's great. Only way togo if you have an AEM EMS. You need a GM boost control solenoid or similar. You can control it like a normal boost controller, RPM, TPS, VSS (Vehicle Speed Sensor) or off a Low/Hi switch. I have used normal setting, VSS and Low/High switch thus far. I prefer the VSS.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
GM Boost Solenoid Part# 1997152 GM Pigtail Part# 12102747
www.gmpartsdirect.com is the cheapest you will find anywhere, unless you steal it!!!!
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
Good luck with it! What's your setup?
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
Sounds like a nasty setup. PM Punkinterviews on here. He should be able to set you up with Precision 1000cc injectors. Who is going to tune your AEM EMS?
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
yeah the last tuner i brought it too before said that i was at like 70 or 80% duty cycle and said to get some bigger injectors. which was glenn who had hybrid performance or something like that now sold the dyno to z fever. but i'm not sure who i'm goin to bring it too. he charged me like 600 for setting up aem and tuning it and his software broke so i did'nt get to see what it was doin power wise. thinking about cft??
