b20 ek?
smokes weed...everyday.
on
b20 ek?
ive been thinking about doing a b20 swap for awhile now, and i was wondering what mounts i would use? is it the same as b16 mounts?
also, most places only sell the longblock, so does anyone know where i can get a complete swap? thanks.
I <3 RooR!!!!!!
I <3 RooR!!!!!!
b20's are the same physical size as a b18 so doing a b20 swap would be identical to swapping a b18 or b16.
on
does anyone know where i can get a COMPLETE swap? ecu/axles/IM shaft/mounts/dizzy and all?
a b20 in particular. thanks.
I <3 RooR!!!!!!
I <3 RooR!!!!!!
hmotorsonline.com
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
Are you looking for a B20z or B20b ? depending on which one want will determine whether you can get a complete swap. Lemme know and I can give you some info on what you need to know.
-Justin
-Justin
R.I.P. Kevin Gonzales Aka Slo_Si
You will be missed by many.
R.I.P. Robert Kolp Aka 00ek
You will be missed brother
R.I.P Jake D Aka Cold_Beer
you will be missed brother
on
thanks man. ide ask jake, but hes not online right now.
it doesnt matter which block it is really, since it'll be getting work done. I know the b20b would probably be easier to get a complete swap, since its older, and most likely cheaper.
whatever you can get, let me know.
I <3 RooR!!!!!!
I <3 RooR!!!!!!
Why would you waste your time with a b20 ?
You can't spray it, you can't boost it...
The cylinder head is useless..
Go with a ls swap, then boost it.
on
why can't i spray it?
and im not into the whole boosting thing right now, ide rather use juice.
I <3 RooR!!!!!!
I <3 RooR!!!!!!
The downfall is the sleeves are known to fail under any kind of forced induction.
Figure out how fast you want to go, then figure out how much power its going to take to get there. Finally, situate your finances for those goals & proceed in an educated manner.
