Need Wiring Help!!!
Need Wiring Help!!!
I have a 1997 Civic Ex
I installed a 1994 OBD I B18B1
I used a stock 98 DX harness and wired in the correct plugs from the OBD I engine harness.
I am using the stock OBD I P75 ecu w/ a conversion harness.
The car starts up and run for a couple of seconds and sounds like it is running pretty good, but then the check engine light comes on and it stalls and backfires out the throttle body.
I thought i messed up a distributor wire, but checked and rechecked and they are all in the right place.
I dont know where to go from here, please someone help.
Thanks
Thanks
hey mike if you want you can give me like 20 minutes and ill come down to d block and check it out if you want...
-pablo
-pablo
RIP Kevin "Slo_Si" You'll be missed by everyone who knew you my nigga.... I'll see you soon man...
mike pm me your number asap i can help you with this..
