h22 knock sensor
It only 2 wires either one is bad/loose or the sensor is. I do not know how much they are new but you can get them on Ebay for like $35.00 delivered. Just ordered one for a customers Y8 swap.
if your vtec kicks in at all it's at full power, honda won't let you in vtec if thier is something really bad, so once you hit vtec it disregaurds those codes.
that's president hussein obama to you :gordy:
Theres a good idea If VTEC engages its on it is not progressive it is on or off. You may not get full power though because it may not advance timing all the way since it sees a fault in one of its primary VTEC sensors to save the engine. I am not 100% sure if the honda ones work this way but I know that factory turbo cars work this way to save engine from overboosting and detonation. My 2 pennies
so what im hearing is that i should chip it so i dont have to worry about the knock sensor, this way i know im getting full potential out of v-tec? if this knock sensor does actually defualts my engine how much power am i losing? just wondering what would be the diffrence when i fix it? thanks alot for the help!
