door molding on 99 teg
I was wondering how I remove the door molding and the best way to shave them. And does anybody know how hard it would be to do type r conversion do the wholes line up and what not thanks.
you need to take off your door panel and take off the 10mm bolt that holds it at the end. there are a couple clips. ( 5-6) of them.. just pinch them and push them through.
and for shaving them.. see if someone can weld those holes shut or weld small squares behind it and use filler
