how many pounds of boost can you run in a d-series
im kinda new to the honda seen i got my car like 5 months ago and i wanna turbo it what would be the best kind of turbo to get. and how many pounds of boost can i safely run??
Guest
Posts: n/a
As has been stated before. It's not the amount of boost that you run in the engine, it's how much horsepower, and how much combustion pressure is in the cylinders.
As the latter is a bit harder to calculate, the bottom end of a WELL tuned D series engine can hold 300ish whp. For a decent amount of time > 1 year.
Now, if you want a safe, moderate tune, and know the engine will last as long as you want it to (with in reason) I would say 250whp is about where you will want to be. With a low 11:1 a/f ratio and moderate timing.
To figure out the best turbo for your needs is a pretty difficult question to ask.
I would first have to ask you, how much power are you wanting to make? How responsive do you want the turbo to be? Do you mind lag? Is this going to be a street car/drag car/auto-x? How deep are your pockets?
With out knowing anything, from personal experience: SOHC VTEC engines love turbo, from small to medium. Even though they have very low displacment, they still spool well. The heads seem to be designed for just this thing. For a street car, with wanting little to no lag. I would suggest going with a straight t3, 50 to 60 trim. This will allow you to make around 220-250whp @ 12-16psi (depending on many things) and have very little lag. (2500-3000rpm full boost).
If you're wanting to make 250whp easy, and have room for more, with moderate lag. I would suggest going for a t3/t4 50 trim with a .48 a/r on the hot side. This will allow you to make full boost from 3500-4000rpm and make 250whp on lower boost pressures. Somewhere around 10-12psi.
Of course there are much more radical and high end turbos you can get, whichi spool fast, and provide much more power potential, but I'll save that for another time.
thanx man . i have a d16z6 head on my car....as it is and my pockets not that deep but i dont mind spending a little money a little lag is something i wouldnt mind i want as much power as i can possibley get!
20 gallion PSI......
Well he already answered some. But if you are going to keep everything stock, I would not run over 12psi with an extremely good tune. Power output will depend on turbo size, condition of the setup and your engine, and how you tune it.
On a General note, with the right size turbo and 10psi you could get anywhere from 180-200whp. The most important thing here is the tuning, it will extend the life of your engine if done right.
2002 Subaru WRX
1988 Honda Civic Hatch
2002 Subaru WRX
Originally Posted by B18C5-EG
It's a D-series keep upping the boost till it blows then buy another one and go 3-5 psi under the deatonation psi
i plan on doing 10psi stock, then building another engine for 30 or so.
I <3 RooR!!!!!!
I <3 RooR!!!!!!
so you understand what detonation is a little better
Originally Posted by 95gainfla
thats not a bad idea since a used d complete block go for like 100-150.
You both need to get a clue... Im sorry but thats one of the stupidest ideas I have heard in a while.
mt I was joking lol thats why i put the " " but I hope no-one took me seriously lol. Im at work and im very bored so the only thing that keeps me alive is having some fun and making jokes.
