vtec controller/vafc
Old Nov 2, 2005 | 07:53 AM
CRXcominup's Avatar
Default vtec controller/vafc???
i heard that the vtec controller was just a little box that hooks up the vtec and i thought the vafc was the same thing until i went online and saw the Apexi VAFC II, and i was just wondering are these the same things that i would need to put a vtec head on?
Old Nov 2, 2005 | 08:12 AM
95gainfla's Avatar
smokes weed...everyday.
uhm..pretty sure to put a vtec head on you just wire up the vtec solenoid.
I <3 RooR!!!!!!
Old Nov 2, 2005 | 11:56 AM
The Spectacle's Avatar
Spent more money than you
you do not need any of these piggy back devices to install a vtec head, a chipped ECU with the right mappings for your head will do much better then a stock non-vtec ECU. however if you would like to further tune the motor after installing both the ECU and head, a piggyback such as a VAFC may do some good. We have a user here with a LS/VTEC putting out just over 200whp that is "tuned" solely on a VAFC. Seems to work well for him. His username is "BigBodySmith"
Racing Integration
LHT Performance
My tuner is named Alpha
Old Nov 2, 2005 | 12:41 PM
CRXcominup's Avatar
so you just wire the noid up to the ecu?
so u dont need either one a vafc or vtec controller for the vtec to actually work?
is there a difference in a stock like (SI) vtec controller and a vafc?
Old Nov 2, 2005 | 01:07 PM
B18C5-EG's Avatar
You do no need a piggyback for what you are trying to do. And depending on what your crx is you may not even need to wire it for vtec cause it may come pre-wired.
Old Nov 2, 2005 | 02:41 PM
CRXcominup's Avatar
its an hf
