SOHC cam turbo setup??
For a D16-T I would do ...
D16Y8 Block with rods/pistons possiblly sleeved if looking for more than 300+WHP
Stock D16Y8 Head with Valvesprings/retainers
GT2871R
Semi Equal Length Mani
TiAl 38/44mm WG
TiAl 50mm BOV
Precesion 680cc Injectors
Precesion 350/600 Core
CMS Piping/DP
Aeromotive FPR
Walbro 255lph
Crome
Thats to do it right . You could cheap out and do things cheaper but in the end you end up with just that a cheaply built/ half asses setup ...
I say sleeve it and put an SC61 w/TO4S Cover and Stage 5 4 bolt T350 Exhuast side and 1000cc Injectors and try to make 500WHP
GT2871R
TiAl 38/44mm WG
TiAl 50mm BOV
CMS Piping/DP
Aeromotive FPR
Walbro 255lph
Crome
Hondata saves lives
Hondata saves lives
Sherman i dont have the cam yet bc i dont know if i am gettin a v-tec head...but i can get a Zex stage 2 for 100 bux if i wanted to....Jay has one....i dont think im going to go vtec any more bc EVERYONE has it i was to be Diff......
im gonna make a thread just for you......its gonna be called....."is it bad to ask question"
and see what ppl say....KK
CHAVEZ MOTORSPORTS
Great Guys, Great Work, Good Choice
CHAVEZ MOTORSPORTS
Guest
Posts: n/a
All of you stop the bullshit highschool drama. Goto honda-tech.com if you want to talk shit. This is a tech forum.
An SC61 is a laggy turbo, i'd stay away from it. The GT series turbos are nice, but pricey.
You can get 250whp with no problems on a stock engine SOHC VTEC. If you have the A6 and Y8 combined, your compression is probably a bit too high for boost with out a lot of tuning. Building the engine is a must, To run much more then 10psi you're prolly going to need to back the shit out of your timing, or run higher octane.
if anything was bullshit drama stuff, its when his friend said he needs to research before he talks. everything after that has been informational.
I <3 RooR!!!!!!
I <3 RooR!!!!!!
Thank you Cronic.
But like I was saying. I agree with everything that Boosted4AG said. Dont use a Side mount just wait the extra xxxxx time and get a FMIC trust me it will be worth it in the long run. Dont skimp corners when it comes to running a turbo setup on your car because you will end up messing something up. You seem fairly anxious to get this on and I would be to
. But like I said take your time buy the right stuff and let Chavez take car of you
Thanks My car is actually at CMS right now..im gettin alot of stuff done....i am planning to take it there anyway....any other info i can use or advice i need...im a newB when it comes to turbo stuff...lol...Thanks TR
CHAVEZ MOTORSPORTS
CHAVEZ MOTORSPORTS
Mike how do u know the motor is Perfect u have never seen it run and u have one person that can vouch for it and it is someone who ripped you off with a clutch....(not sayin any names) u have never heard it run.....just an opinion dont FLIP....i have been thinkin bout that for a while thats Y im IFFY on Buyin it...LMK
CHAVEZ MOTORSPORTS
CHAVEZ MOTORSPORTS
