radiator question
i plan on goin turbo on my 97 integra and will I have to do anything to the radiator or fans
i plan on using drag or revhard manifold and a t3 or a t3/t4 |
i plan on using drag or revhard manifold and a t3 or a t3/t4 the coolant, and be slightly thicker in the core section. Not so good rads have only one tube carrying the coolant. An innovative person would put in a thicker radiator from another car, and make/adapt their own brackets to hold it in; lining up the hoses as needed.-Bob |
I think he means more fitting the turbo and not having to change the radiator to a half size rad from like a 92-95 civic.
Some of their cast manifold, revhard and drag, are part of kits that will be complete bolt ons so no additional modifications would be needed. But it also depends on the size of the turbo you will run, there's many different T3's and T3/T4's. If you duplicate one of their kits, you should be fine with those parts and your stock radiator. |
