Turbo set-up Opinions/experiences. go or no-go?
Old Oct 18, 2005 | 05:48 PM
mtber's Avatar
Originally Posted by DA92driver
another question. they are chipping my stock ecm and dyno tunning the car. would i be pretty set as far as engine management? or would i need to keep it in line cheap with maybe a vafc 2? or run a more expensive set up i.e hondata, AEM etc..??
Convert to obd1, get tuned on crome.
Old Oct 18, 2005 | 05:49 PM
mtber's Avatar
how long has he had the set up on the ls? and what size turbo.?
also whats the recomended seating mileage for new rings? 500-600 miles?
Stock ls motor, sc34 turbo...
Rings seat quicker then most people think there are dozens of brake in concepts, choose one
Old Oct 19, 2005 | 06:09 AM
KJ's Avatar
KJ
bored at work
Really your rings are seated after the first 20 minutes of the car running. 50 miles and you are good to go.
Old Oct 19, 2005 | 06:34 AM
davcivic's Avatar
El Mas turboso
As far as the chipping and tuning, that's all you need. They will probably use Turboedit or something similar, it's pretty much a standalone, depending on how they do it. Much better than an AFC and cheaper than Hondata.
For only 10-13 psi daily driven, you really don't need to build anything, except if you have high high miles, then you might want a quick build up, but factory parts will hold that power fine.
For all the work they are doing, the price seems really good to me. Do it.
2002 Subaru WRX
1988 Honda Civic Hatch
Old Oct 19, 2005 | 07:17 AM
SPOONCIVIC's Avatar
FUCKIN LOOONG BEDD!!!
id throw some aftermarket pistons and rods in there.then you'd be alittle safer for not much more
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
Old Oct 19, 2005 | 04:59 PM
  #17 (permalink)
DA92driver's Avatar
thanks for the input guys. i found on g2ic.com that there is another g2 with a bone stock ls, and after tunning with turboedit he made 279.3whp and 260 lbft torque. id say thats pretty effing good on a stock b18a.(t3t4 )
Old Oct 19, 2005 | 05:00 PM
  #18 (permalink)
DA92driver's Avatar
cant wait till it happens!
Old Oct 22, 2005 | 06:00 PM
  #19 (permalink)
juiced2ndgenteg's Avatar
all done by CFT for $5758.
wow, big numbers....
Old Oct 23, 2005 | 07:18 AM
  #20 (permalink)
lowoctane's Avatar
Professional Dumbass
thats what i said..wow...and stay away from block gaurds, garbage.
i'd say if your engine needs some healthing up, just rebuild it. Change all your basic goods, as far as pumps, belts and seals, rebuilding it, and you'll be good to go with tad bit over 9psi..making over ~200whp, which isnt bad.
a lot cheaper than 6k.
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
