turbo question
Old Oct 12, 2005 | 05:27 AM
ChrisMonsod's Avatar
Drives a cowboy corvette
Default turbo question
ok heres my set up
b18b
SRP Pistons 8.5 comp
Eagle Rods
KMS blockguard
Rev Hard stage 2C Turbo Kit
turbo smart wastegate
greddy bov
T3/T04E precision turbo
Exedy Stage 3 clutch
greddy profec EBC
HKS timer
2.5 piping
FMU w/inline fuel pump
daily boost running 7psi
now nothing seems wrong with the car it pulls like a mofo and starts to
lose traction.. but my concern is when i shift something under the hood make a rattle snake sound.. its real hard to explain unless you hear it.
i know what the bov sounds like but im not sure if its adjusted right
could it be the noise of a waste gate? its running open atmosphere.
or is it a compressor surge, but theres no lose of power @ all
anyone ?
Old Oct 12, 2005 | 05:40 AM
japanbran's Avatar
Bo0st FTMFW
i would say compressor surge. try to adjust the bov.. loosen it.
phearable.net
R.I.P DJSTANG. YOU WILL NOT BE FORGOTTEN!!!!
Old Oct 12, 2005 | 07:01 AM
well i just went outside to mess with it.. its at the softest setting and i even went as far as to remove one spring. this causes it to leak because i feel air coming out the bov and i still here the rattle ..
its comming from the air filter thats on the turbo so yeah its gotta be compression surge.. my only other thought is that i have the profec B spec II the wastegate the boost gauge and the BOV running off the same vaccume ...
could this be the problem ? not enought vaccume to work the bov so its not opening fast enought to release pressure? maybe i can shorten my vac line? or tap into another line ? any ideas?
davcivic's Avatar
El Mas turboso
Like metal ratling our air moving. It could be the wastegate if it is like you said dumping to atmosphere. Or compressor surge, kinda hard to tell without hearing it.
Does it do it under load only, running, or will it do it parked if you rev it up?
2002 Subaru WRX
1988 Honda Civic Hatch
Old Oct 12, 2005 | 07:34 AM
it will do it both .. and the sound does not come from the wastegate.. its from the filter that is on the turbo
Old Oct 12, 2005 | 07:42 AM
davcivic's Avatar
El Mas turboso
Ok take the filter off and try again, make sure there's nothing in there loose.
If it happens again, try to adjust the BOV.
2002 Subaru WRX
Old Oct 12, 2005 | 07:48 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
Its is because you have too many vaccuum's tee'd off of one source... They all need independent sources... I would invest in a vaccuum manifold if i were you
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Oct 12, 2005 | 08:04 AM
tapped in to the pcv vaccume gonna take it for a ride now .. seems to be ok on idle ..
thanks to the TR guys and thanks to honda-tech for there input.. ill tell you how it goes when i get back
Old Oct 12, 2005 | 08:15 AM
seems good for now but that compressor surge sounded cool as hell
but now my boost gauge is reading 6 psi .. might need to adjust that BOV a bit more ,,
might be a leak
Old Oct 12, 2005 | 08:46 AM
Retired Ricer...
Do not tap into the pcv vaccuum source... Thats a good way to clog all of your vaccum lines with oil... As I said before, get a vaccuum manifold, and tap it into the brake booster BEFORE the check valve...
