zex trigger wire?
ok im got a zex wet kit. all lines ran foggers in, and got the arming switch and ground hooked up. all i need to know is which of the 3 wires on the tps do i put the white wire on the zex. if anyone know please help me
i think its red and yellow im not real sure on the pin strip but im for sure its the red one its the only red one in thaqt little harness i went right uder the tps but yea man its red one for sure gook luck
[SIGPIC][/
SIGPIC]
[SIGPIC][/
SIGPIC]
ok found out how to program wot. so i did. i armed teh system pushed teh black button on the side held the throttle at wot for 10 seconds. turned it off then turned it back on to give it a try. solenoids open once and wont open again. but if i put it to a staight 12v it will work all day (threw a push botton). i read somewhere that teh tps needs to put out atleast 4.5v to activate it so i guess that will be my next step
well i gave up on teh tps, so i was thinking how to activate it and didnt want to drill and holes.................. well long story short i wired it to my front windsheild motor because my hood squirters are shaved. keeps my hands next to the wheel and uses the same hand i shift with
