eg rear disc conversion
Hi guys I am planning to to a rear disc conversion to my 92 eg h/b and I just wonder from what year and model they fit my car ? and also which one is better ? Thanks.........Omar
all the years fit from the 90-up integras the eg si's 99-00si
just get fron the trailing arm back. and get the e-brake cable.
you should get either a 15/16 1'' or 7/8ths master/brake booster combo and a 40/40 proportion valve.
if you don't get the larger master cylinder you will have to push your pedal alot further to the ground do to the size of the smaller piston in your 13/16ths master, the smaller piston take more force to engadge the rear pistons than it did to engage the wheel cylinders. so thats a good upgrade to do during the conversion.
