no cluster lights
Old Oct 6, 2005 | 11:53 AM
supra87's Avatar
Default no cluster lights
just got a 89 crx yesterday, no cluster lights(tach,coolant temp, gas gauge, speedo) , checked the fuse and its good. dont know what to do next? any help would be great. thanks
Old Oct 6, 2005 | 12:10 PM
methree's Avatar
loser x.x
maybe they pulled teh bulbs out?
i dont know why people dont take me seriously....now wheres my crack pipe
Old Oct 6, 2005 | 02:42 PM
When you put a test light on either/both of the brass connectors for one of those bulbs, does it indicate that you have current?-Bob
Old Oct 7, 2005 | 03:29 AM
supra87's Avatar
yes, i have current and all the bulbs are new as of right before my first post. do you think that maybe the cluster is bad inside? i want to get a cluster out of an SI model anyways. thanks
Old Oct 7, 2005 | 07:15 AM
Next test: do a continuity test on the new bulbs. Sometimes
no continuity, = bad bulb, even new.
Next test:
There should be an electrical plug going into the back of the panel.
It will be the same plug that will plug into your new SI cluster.
With things turned on, test for voltage in the back of the plug,
where the wires come in.............no voltage means the new cluster
will not work either.........also hokey as it sounds, wiggle the plug.
In FL, light corrosion will be rubbed away, and the lights, etc come
on.-Bob
Old Oct 7, 2005 | 10:14 AM
supra87's Avatar
thanks for all the help everyone, i finally got it!!! on the back of the cluster, the circuit was fried so i fixed it and also the dimmer switch is blown, so i just jumped the two wires on the switch and now i got some lights!!!! thanks to all that helped
