port and polish advise
Old Oct 4, 2005 | 04:54 PM
therainforest's Avatar
iam with everyone else on this porting the head with stock cams and stock compression can acually hurt you. sometimes less is more. if your ports are too big the air wont have enough velocity to enter or escape through the ports due to the fact that you are not pushing or pulling any more air then before but you have a larger diameter area to push it through you will most likely lose power untill you up the amount of air or boom happening in the engine
Old Oct 4, 2005 | 04:59 PM
rangcrx's Avatar
engine building &best
what?
i love AUTOZONE
Old Oct 4, 2005 | 05:11 PM
BoogieDown's Avatar
Area Man
I have a PnP Z6 head and intake and when i put the head on(stock Z6bottom) i noticed a power loss. Still have my stock 88DX exhaust. Hope a better exhaust and tuneing will help me some.
Old Oct 4, 2005 | 06:18 PM
98HATCH's Avatar
besides the boltons and the bottom ends what is the first thing i should do i was thinking camgears for now i got to change the timing belt any ways ????
0 TO 60 IN 5 MINUTES
Old Oct 4, 2005 | 06:20 PM
98HATCH's Avatar
oh i have another question i have asmall oil leak around where the vtec solenoid meets the cylinder head will tht affect the activation of the vtec do u think its the gasket
Old Oct 4, 2005 | 06:21 PM
rangcrx's Avatar
for a b16 it has nice compression and rev power so better higher lift cams a exhust are the best easiest ways for more power..then next add some ctr pistons arp bolts better valve springs and clutch
i love AUTOZONE
Old Oct 4, 2005 | 07:05 PM
  #17 (permalink)
freakasis's Avatar
upgrade the head(springs retainers, cams...ect) first. and when you build the bottom end then p&p the head. that way you dont have to remove it twice. and you prolly wont be getting it retuned after each extra mod, right?
you will not lose power because of the air not having enough power to get it. it will have plenty of suck power. they problem is that the air will be going in faster than the stock ecu "thinks" it is (since it measures pressure not air flow) and thus throwing off your a/f, and decreasing power. probably by noticable amounts since a good p&p will make a BIG differance in flow.`
Old Oct 4, 2005 | 07:42 PM
  #18 (permalink)
BoogieDown's Avatar
Area Man
probly the gasket, its only 16$ at the dealer. Only place I know of that has them.
Old Oct 9, 2005 | 04:49 PM
  #19 (permalink)
98HATCH's Avatar
some times there ia delay in activation you hear it and like a whole second later it pulls i have an ls tranny on it , th t may be the reason but i dont know ? i bought like tht. thnks for the advise it all makes sence
Old Oct 10, 2005 | 07:55 AM
  #20 (permalink)
BoogieDown's Avatar
Area Man
I have read where when vtec engauges it does take a second to be fully functional. your going from one cam profile to another and doing so you change the amount of air entering and exiting the cylinders. this won't happen in an instant.
As far as porting goes I put a Z6 ported on my stock Z6 block about a weekago. At first it was very lazy almost like the stock DPFI. I thought I made a big mistake. I was told advanced my timeing about 20 deg. and it was like driveing a new car. fuel milage had droped considerably and idle bounces few hundred rpm at idle but my need to adjust the AF screw.
