Low resistance plug wires for turbo set up?
set aside that they are illegal on the street and all, if i was to say push 13 psi, with the compression ratio 9.2:1 on an almost stock Ls b18a would i need a stronger spark? i dont want to upgrade the coil yet, or would the stock ignition do fine with the low boost?
also, will i need to change the MAP sensor after boosting it? thanks in advance.
Originally Posted by 99B16Si
use your stock ignition and gap some colder plugs down and itll work perfect.
ZMRacin...for the people since 1998.
typeZ
zionmotoracin@gmail.com
> #zionmoto #s1built #battlegroup3<
drag honda / drift soarer / road race benz
typeZ
zionmotoracin@gmail.com> #zionmoto #s1built #battlegroup3<
