idle on a 92 teg
Old Aug 26, 2005 | 10:15 AM
chondacrx's Avatar
gangster
Default idle on a 92 teg
i have a 92 teg with a b18b1 motor and manifold... i'm not throwing any codes but its not idling right... it idles at 1300 then it goes up to 2000 or more thenseconds later it goes back down to 1300...
does anyone no y it would do this...
Old Aug 27, 2005 | 05:57 AM
dippincrx's Avatar
save the s.o.h.c
check your air idle control vavle on teh back of the intake manifold sometimes that causes a engine to surge
Old Aug 27, 2005 | 09:28 AM
Old Renegade's Avatar
Cool Runnings
tps might be bad throttle position sensor.
Old Aug 27, 2005 | 09:35 AM
chondacrx's Avatar
gangster
ok thanks everyone
Old Aug 27, 2005 | 04:49 PM
DOHC16CRX's Avatar
CARPET GUY
if you want to bring it by me some time i will check it out for ya..you have my #
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Aug 27, 2005 | 08:53 PM
DA92driver's Avatar
happend to mine the other day. for me it was as simple as a hose being disconnected. check and see that all the hoses to and from your intake manifold are conected. -greg
Old Aug 27, 2005 | 09:20 PM
chondacrx's Avatar
gangster
nate i will give u a call... thanks
Old Aug 27, 2005 | 09:25 PM
chondacrx's Avatar
gangster
and sometimes it doesnt want to start and after alittle it starts..does any one no what could make it do that too
Old Aug 27, 2005 | 10:03 PM
calloway01's Avatar
Big block
if the Intake manifold is off an automatic and you have a vacuum line ran to the EGR it will idle messed up.... Also has your CEL came on before ??does the Cel light up before you start it , if not check the bulb in your guage cluster.
Big block mustang killer...get some
-Mike
Old Aug 27, 2005 | 11:10 PM
chondacrx's Avatar
gangster
whats the cel light
